EXIF not showing
Roger_PT
EXIF not showing
Post by Roger_PT »
EXIF info is not shown from my Minolta MRW Raw files which could be annoying though not surprising, but it is weird not getting the EXIF info either from TIF files generated with Photoshop from those MRW.
Roger
Re: EXIF not showing
Roger_PT wrote:EXIF info is not shown from my Minolta MRW Raw files which could be annoying though not surprising, but it is weird not getting the EXIF info either from TIF files generated with Photoshop from those MRW.
Currently EXIF is not shown for Camera RAW format...
Post by Guest »
Neither for TIFF files????
Thanks,
Roger
Post by Guest »
Also if I convert those TIFFs to JPEG using VnView the EXIF info is gone.
Roger
Anonymous wrote:Also if I convert those TIFFs to JPEG using VnView the EXIF info is gone.
Roger
Yes, TIFF exif is not supported.
