Bad implementation of the folder rename
m.Th.
Post by m.Th. »
Sometimes the folder cannot be renamed.
But also when the folder can be renamed from the Folders tree, instead of just changing the value in the Folders table, the directory is just rescanned again which can be problematic especially if the folder is big.
m. Th.
schultzter
Re: Bad implementation of the folder rename
Post by schultzter »
Also, in the Favourites Tree View it will let you rename a folder but it won't actually rename the folder on the disk!
Version 0.72 x64 (Dec 19 2014) on Arch Linux
Headed for the second star to the right and straight on 'til morning...
schultzter wrote:Also, in the Favourites Tree View it will let you rename a folder but it won't actually rename the folder on the disk!
you rename the favorite name not folder
See Issue 687 for current status and details.
This problem is supposed to be fixed in XnView MP 0.75 or later. Could you please try and confirm the bug fix, m.Th.?
m.Th.
Post by m.Th. »
Well...
The dump:
94a1f443-b0bc-4a97-a73b-7dce0034b174.zip
(21.54 KiB) Downloaded 94 times
(I tried to rename a test folder on C: from „f1” to „f 1”)
m. Th.
Thank you for your checking and reporting back, m.Th.. A crash is not quite the expected result. :?
Does the crash occur with renaming of a folder? Could you please provide more info so that other people and Pierre can try to reproduce it?
:arrow: New
m.Th.
Post by m.Th. »
We're working on this with Pierre and it seems that it is fixed.
m. Th.
m.Th. wrote:We're working on this with Pierre and it seems that it is fixed.
Good to read.
:arrow: Reproduced
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
