1st bug - when I press Tab key it should switch also to extension field, I think. I suggest this order - name>extension>ok>cancel (current order - name>cancel>ok>cancel>ok...).
2nd bug - when I rename file to existing name, it's not renamed and there is no error dialog box, so I could think file is renamed.
Rename file dialog box in fullscreen & viewer - 2 bugs
Re: Rename file dialog box in fullscreen & viewer - 2 bu
Ok, i'll check...Dreamer wrote:1st bug - when I press Tab key it should switch also to extension field, I think. I suggest this order - name>extension>ok>cancel (current order - name>cancel>ok>cancel>ok...).
Yes, the order you propose is good.Dreamer wrote:1st bug - when I press Tab key it should switch also to extension field, I think. I suggest this order - name>extension>ok>cancel (current order - name>cancel>ok>cancel>ok...).
I think when renaming one file, this is obvious to the user (there's the preview). Why should an error message occur?Dreamer wrote:2nd bug - when I rename file to existing name, it's not renamed and there is no error dialog box, so I could think file is renamed.
Because when I rename image (in fullscreen) to existing name, I suppose that it's renamed, how could I know that there is another image with the same name in the current folder with e.g. 500 images?helmut wrote:I think when renaming one file, this is obvious to the user (there's the preview). Why should an error message occur?Dreamer wrote:2nd bug - when I rename file to existing name, it's not renamed and there is no error dialog box, so I could think file is renamed.
When renaming files, XnView will ensure that no existing file will be overwritten. So I still see no need to display a message message.Dreamer wrote:...
But when I rename image, I don't know that it's not renamed, I need to know that I must use another name.helmut wrote:When renaming files, XnView will ensure that no existing file will be overwritten. So I still see no need to display a message message.
E.g.:
- there are 500 images in folder
- also these images - 001.jpg, 002.jpg, 003.jpg, 004.jpg, 005.jpg and 01.jpg, 02.jpg, 03.jpg, 04.jpg, 05.jpg
- I rename these images in fullscreen - 01.jpg, 02.jpg, 03.jpg, 04.jpg, 05.jpg to 001.jpg, 002.jpg, 003.jpg, 004.jpg, 005.jpg
- I suppose that images have been renamed (since there is no error dialog box) and close xnview
- and imagine that you rename 50 (or more) images like that
- you'd have 50 (or more) images with the "wrong" names
- and now imagine that you burn them to CD
I think it's a quite danger bug, you could sort and rename lot of images even few hours and then you'll see that some images are not renamed - and you don't know what images have the correct names, so you must check all images again...
Have you tried out your example? For all I know, XnView will show an error message if files already exist and you will have to change the file template.Dreamer wrote:...
Of course.helmut wrote:Have you tried out your example? For all I know, XnView will show an error message if files already exist and you will have to change the file template.Dreamer wrote:...
Try this:Dreamer wrote:Rename file dialog box in fullscreen & viewer - 2 bugs
- create images 1.jpg and 2.jpg (in the same folder)
- try to rename image 2.jpg to 1.jpg in browser
- try to rename image 2.jpg to 1.jpg in viewer
= there is no error dialog box in viewer (and in fullscreen - standard and lite)
