How to install GFL SDK 3.4
Nols Smit
Post by Nols Smit »
I'm using GFL SDK on Windows 7 with Delphi XE4
Is there a similar install program, such as GflSDKSetup.exe for version 3.11, to install version 3.4 ?
Regards,
Nols Smit
Nols Smit
Re: How to install GFL SDK 3.4 - Solved
Post by Nols Smit »
Ok, I got it to work. You do not install anything, copy libgfl.pas to the folder of you Delphi source and the *.dll files to the path of your .exe file.
With nearly 4000 re-sized photos loaded (longest side = 300 pixels), the size of the database (FireBird v 2.5) of one of my application is only 170 MB.
See uploaded example (Delphi XE4).
Regards,
Nols Smit
Demo.zip
(693.11 KiB) Downloaded 352 times
