PX/Inch Change to PX/CM on image conversion
qrayg
Post by qrayg »
Whenever I convert one of my current images(without resizing) from PSD to PNG it changes the image so that when I open it in another program it thinks the image is set to centimeters instead of inches.
I've tested this with the batch conversion and the simple "save as". I've opened the original image in Fireworks and it says the image is in inches. I save the image as PNG and then open the new image in Fireworks and it says it is in centimeters.
I've tried saving PSD's as GIF and JPG and it retains the inches units. Whenever I save as PNG though it changes to centimeters.
Re: PX/Inch Change to PX/CM on image conversion
qrayg wrote:Whenever I convert one of my current images(without resizing) from PSD to PNG it changes the image so that when I open it in another program it thinks the image is set to centimeters instead of inches.
Yes right, i save always PNG with cm info. Could you send a PNG sample, please?
Always in inches...
qrayg
Post by qrayg »
Here's a sample set of images. I created a PSD with units set to inches and converted it to PNG with XnView v1.80.1 and now its units are set to Centimeters.
qrayg wrote:Here's a sample set of images. I created a PSD with units set to inches and converted it to PNG with XnView v1.80.1 and now its units are set to Centimeters.
Strange, in PNG resolution can only be saved in CM
