Build thumbnails hangs with empty cache list
ijx77
Post by ijx77 »
With the DB cached directory list empty, the "rebuild thumbnails" process never finishes, ~0% cpu.
(works as planned with any contents listed in cache)
Also the use of "excluded/included" folders in DB settings can be confusing - I added an included folder as sub folder of excluded folder in the DB settings .. I expected it to have thumbnails built for it after pressing "rebuild thumbnails" but this didn't happen. Is this a bug? Is there a way to add folders to the thumbnail cache through settings?
m.Th.
Re: Build thumbnails hangs with empty cache list
Post by m.Th. »
Yep - funny one. But you have the 'Abort' there.
Also the use of "excluded/included" folders in DB settings can be confusing...
+1
I leave Pierre to answer here, but I think that for your subfolder the thumbnails will be build + stored IF you enter in that subfolder. REbuild thumbnails REbuilds the EXISTING thumbnails.
Tools | Settings | Database | Add folder... (a button in lower-right corner) - It works recursively with the entire subtree. Hence if you choose Add Folder and select the root of your drive, then entire disk will be indexed. Usually these tasks should be done overnight of course.
m. Th.
ijx77
Post by ijx77 »
Thanks again. I didn't realise it was recursive.
ijx77 wrote:With the DB cached directory list empty, the "rebuild thumbnails" process never finishes, ~0% cpu.
See Issue 317 for current status and details.
seems to work for me...
m.Th.
Post by m.Th. »
What means "work"?
Beware, he thinks that having the following steps...
1. Go to Database | Excluded / Included
2. Add a folder which isn't in the DB yet. Make this folder 'Included' without going with XnViewMP to 'see' what is in it (iow to build the thumbs).
3. Press 'Rebuild Thumbnails'
...will build the thumbs also for the folder at Step 2. Is this the case?
ISTM that Included/Excluded needs a manual scan by going in that folder to have the thumbs built.
m. Th.
