Toolbar item "show files in subfolder" doesn't show state
ijx77
Post by ijx77 »
The browser toolbar item "show files in subfolder" doesn't show its state (ie on/off - grey/not grey etc)
m.Th.
Re: Toolbar item "show files in subfolder" doesn't show stat
Post by m.Th. »
ijx77 wrote:The browser toolbar item "show files in subfolder" doesn't show its state (ie on/off - grey/not grey etc)
Screenshot?
m. Th.
ijx77
Post by ijx77 »
Screenshot?
You want a screenshot of what? it not doing anything - there's nothing to show??
ijx77
Post by ijx77 »
ok in case it's non obvious here are some screenshots - I've annoted them..
Example of buttons that show status ("on/off")
example of button status visual display.jpg (44.31 KiB) Viewed 2491 times
"show files in subfolder button" (showing hover state, not status, mouse cursor not captured)
button that does not show status.jpg (46.03 KiB) Viewed 2491 times
If I click this it has an "on/off" state, but doesn't register it visually.
m.Th.
Post by m.Th. »
ijx77 wrote:ok in case it's non obvious here are some screenshots - I've annoted them..
Aha! - sorry I don't use that button. I do it from the Right-Click menu in Folders tree.
Of course I don't know - but I find it quite difficult to mange the state there because even if is just one way to go in (by executing the same piece of code) it might be many paths to go out (change folder, filter, search etc.). But if it is simple, then I'd vote for it. We surely need a visual clue that we are in flat view of the folder.
m. Th.
Problem still exists in v0.84: When activating "Show files in subfolders" the toolbar button isn't "checked" (remains pressed).
:arrow: Reproduced
helmut wrote:Problem still exists in v0.84: When activating "Show files in subfolders" the toolbar button isn't "checked" (remains pressed).
you means the button "Show files in subfolders"?
Yes.
oh it remains pressed after changing the current folder, right?
xnview wrote:oh it remains pressed after changing the current folder, right?
No.
If you click on the button "Show files in subfolder", XnView will switch to "show folders recursively" mode until you press the button, again. (correct).
Problem: The button does not indicate this "show folders recursively" mode. I.e. when looking at the toolbar button the user cannot see that "Show folders recursively" is active or not.
Re: Toolbar item "show files in subfolder" doesn't show state
O.k., thank you, I can also reproduce the problem. Issue 1247 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Tested in 0.87 beta 2, fixed.
The button stays pressed untill recursive mode is exited by selecting a folder in the tree pane.
And, after right-click on a folder in the tree pane and selecting Show all files (recursive), the button also gets a pressed state.
