Hi all,
Since probably i updated MacOSX 10.9.2., when i open XnRetro and click the Open menu, the flying window opens and shut down instantly ;(
I've reinstalled the software but nothing changes ;(
Can you help me ?
Thanks a lot.
XnRetro v1.28 open file window shutdown MAC OS X 10.9
Re: XnView Retro v1.28 open file window shutdown MAC OS X 10
Hi,ULK wrote:Hi all,
Since probably i updated MacOSX 10.9.2., when i open Xnretro and click the Open menu, the flying window opens and shut down instantly ;(
Can you help me ?
Thanks a lot.
IMHO you posted in the wrong forum. The correct forum (AFAIS) is here: http://newsgroup.xnview.com/viewforum.php?f=81
Btw, if by "flying window" you mean the popup window which allows you to select a file, then, most probably, it could be something related to the last directory/file which you opened/accessed before - perhaps this file / folder disappeared/it was deleted?
I don't know on Macs but on Windows is a common problem. It is a problem of OS rather of the program.
Good luck and next time please post in the correct forum
m. Th.
- Dark Themed XnViewMP 1.0 64bit on Win10 x64 -
I knew that it was not the absolutely right topic for Xnretro but there is no BUG topic there.
Do i need to move it ?
Your analysis is probably right for the bug. I don't know how i can reset the last path ;(
Ok, i need to update XnReto for 10.9
Thanks a lotxnview wrote:Ok, i need to update XnReto for 10.9
Do you have always the problem?ULK wrote:Thanks a lotxnview wrote:Ok, i need to update XnReto for 10.9
No. It works fine ! Thanxxnview wrote:Do you have always the problem?ULK wrote:Thanks a lotxnview wrote:Ok, i need to update XnReto for 10.9
No more access to the open file menu ;(
OS : OS X 10.9.5 (13F34)
An update ?
An update ?
what's hapened? do you have changed something??ULK wrote:No more access to the open file menu ;(
An update ?
that's fine today
