XnConvert Crashes on osx 10.9.2
luis
Post by luis »
Hi
I just updated xnconvert to 1.63 running osx 10.9.2 on imac and as soon as I drop a bunch of jpg to be converted it crashes.
here's a part of the crash report.
Process: XnConvert [2675]
Path: /Applications/XnConvert.app/Contents/MacOS/XnConvert
Identifier: com.xnview.XnConvert
Version: 1.63 (1.63)
App Item ID: 436203431
App External ID: 369302686
Code Type: X86-64 (Native)
Parent Process: launchd [220]
Responsible: XnConvert [2675]
User ID: 501
Date/Time: 2014-02-27 14:53:42.783 +0100
OS Version: Mac OS X 10.9.2 (13C64)
Report Version: 11
Anonymous UUID: 353BE71A-A7DA-4BCD-5B90-970B99B3A4B1
Sleep/Wake UUID: 88A852CE-DE4D-492A-963B-9882F648F375
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: '<NSRemoteView: 0x101d5e370> is invalid, thus its bridge cannot be raised'
abort() called
terminating with uncaught exception of type NSException
Any help would be appreciated.
Thanks
Luis
Re: XnConvert Crashes on osx 10.9.2
and no problem from last version? Do you use XnConvert from my website or apple store?
luis
Post by luis »
Hi Pierre
never had problems...and I updated from your site not Apple.
Thanks.
I've tried on 10.9.2, with the version from my website, and no problem if i drag&drop a jpeg file :(
Could you try to remove the file Library/Preferences/com.xnview.XnConvert.plist?
luis
Post by luis »
Hi Pierre
That was the first thing I tried but It did not work for me.
Thanks
Luis
Same thing if you use 'add file'?
luis
Post by luis »
Hi Pierre
I uninstalled then reinstalled run disk utilities and its finally working again.
Probably os x 10.9 was having a bad week.
Thanks for your help and time.
Luis
