"Save as - Dialogue" - last visted is empty
All non-XnView related: softwares, formats, imaging, photography...
Peter2
Post by Peter2 »
The dialogue for "Save as ...." has on the left side the standard-Windows-bar with "Computer / Desktop / Last visited / ...". For me (Win 7 x64, XnView 2.13) the list for "Last visited" is always empty..
Bug or wrong settings?
Peter
XnView 2.51.0 German, XnConvert 1.95, Win 10
Moderator & Librarian
Re: "Save as - Dialogue" - last visted is empty
Peter2 wrote:Bug or wrong settings?
Is Purge 'Most Recently Used Files & Directories' on exit (Tools » Options... » Interface » Interface » Recent lists) activated?
Peter2
Post by Peter2 »
XnTriq wrote:Is Purge 'Most Recently Used Files & Directories' on exit (Tools » Options... » Interface » Interface » Recent lists) activated?
No, it is not active.
Peter
Did you find a solution, Peter?
Peter2
Post by Peter2 »
XnTriq wrote:Did you find a solution, Peter?
Hi XnTriq
no solution at the moment. I tried the way you linked, but this is only for start-menu.
Peter
Peter2 wrote:no solution at the moment...
Is your XnView copy installed or the zip version?
Peter2
Post by Peter2 »
cday wrote:Is your XnView copy installed or the zip version?
Installed - every update.
Peter
Peter2 wrote:Installed - every update.
No problem with XnView installed on my Windows 7 x64 run from a User account, File > Save As... > Recent Places populated...
Have you tried uninstalling and then re-installing XnView? Yes, basic, I know...
Peter2
Post by Peter2 »
cday wrote:...Have you tried uninstalling and then re-installing XnView? Yes, basic, I know...
I just tried, removed all INIs - just the same.
But maybe we talk about different things?
Peter
Peter2 wrote:But maybe we talk about different things?
I don't think so, and my limited German translates 'Zuletzt besucht' as 'last visit', which is similar to 'Recent Places' although singular I think... :)
it's not a problem of XnView but a setting of your windows
Peter2
Post by Peter2 »
xnview wrote:it's not a problem of XnView but a setting of your windows
Pierre, do you know where to find?
Peter
I've moved the topic moved from General Support to Miscellaneous.
@Peter: Have you tried disabling & re-activating Recent Places? How about resetting Favorites?
Peter2
Post by Peter2 »
Hi
thanks to all for the lot of contributions. It seem to be a problem of Win7 that there is mixture/confusion between "Task bar" and "Recent places" and so many way to change something (gpedit, registry, context menu, main menu, ...)
At last, I could solve it on this way:
cday wrote:The simplest test, leaving aside the possibility of a corrupted registry, is to simply right click on the Task bar, click on 'Properties', select the Start Menu tab, and check and if necessary enable the two 'Privacy' checkboxes 'Store,,,' and 'Store...'
As said above, these options talk about "Start menu" and "Task bar" and not about "Recent places" :x - but it solves the problem.
Have a fine day.
Peter
Screenshots courtesy of our compadre cday
… and from the blog entry I linked to in one of my previous posts:
Windows 7 Help Forums ([url=http://www.sevenforums.com/tutorials/104503-recent-items-enable-disable.html]Recent Items - Enable or Disable[/url]) wrote:
EXAMPLE: Recent Items Enabled and Disable
NOTE: When disabled, you will notice the the Store and display recently opened items in the Start Menu and tasbar option is grayed out it Start Menu Properties.
  • Image Image
