Build thumbnails hangs on .json file
ijx77
Post by ijx77 »
After starting a "rebuild thumbnails" the program consistently hangs on a file named "_exceptions.json" - the file i very simple - I can't see any reason why it would be a problem.
The file is my own related to automated backups - is it a filename clash ?
Re: Build thumbnails hangs on .json file
could you send me the file?
ijx77
Post by ijx77 »
It's just a text file with a .json extension containing the text:
"epw034259": true,
"epw016430": true,
"epw016431": true,
"eaw013869": true
How do I send it? email? can't find address found it - should be attached to an email
ijx77
Post by ijx77 »
ok - I pressed "optimise" button in the database settings, and afterward the "rebuild process" worked to completion - no idea what the issue was or how it was solved.
