Problems with double-click to switch mode
anonymous_user
Post by anonymous_user »
1. Under Settings -> Interface -> Switching mode, the option for "Use double click to switch between:" will always reset to the default/first option of "Browser <> Fullscreen | Viewer <> Fullscreen". If I change it to another option, click OK, and return to settings, it will change back.
2. Even with the default option, double-clicking will always switch between the browser and the viewer. I cannot use double-click to go Fullscreen.
I am using XnViewMP 0.64 portable on Windows 8 Pro 32-bit.
cicciobello
Re: Problems with double-click to switch mode
Post by cicciobello »
Modify Ini file manually to bypass bug.
anonymous_user
I was wondering if someone had reported this already; I'll try to do a better job of searching next time.
