Could you please add "File Name" to the items of the Thumbnail Labels (Default=ON), so that one could decide to show/hide it and choose its position in the labels?
It would also be nice to be able to select in this panel:
- Font used for labels
- Color of text
- Color of background +a check box: "same as background color"
Thank you,
Olivier
Font and Colors of Thumbnail Labels +"File Name"
Re: Font and Colors of Thumbnail Labels +"File Name&quo
i support that idea! please add that feature.Olivier_G wrote:Could you please add "File Name" to the items of the Thumbnail Labels (Default=ON), so that one could decide to show/hide it and choose its position in the labels?
- Color of text
"Color of text" is very important as for now there is no way to have a black background and black thumb-back and a white font.
if i set all the colors to black, a cannot read the font on folders. only on thumbs for pictures.
"Font used for labels" ofcourse, the font and the fontsize must be customizeable by the user.
loth
Ok, i'll add it, but currently i use an internal color for filename, and text color setting for others labels... Is it a problem if all labels (even filename) are with the same color?Olivier_G wrote:Could you please add "File Name" to the items of the Thumbnail Labels (Default=ON), so that one could decide to show/hide it and choose its position in the labels?
okIt would also be nice to be able to select in this panel:
- Color of text
No problem at all: it's fine for me.xnview wrote:Is it a problem if all labels (even filename) are with the same color?
Thank you, Pierre.
Olivier
No problem for me too.Olivier_G wrote:No problem at all: it's fine for me.xnview wrote:Is it a problem if all labels (even filename) are with the same color?
Thank you, Pierre.
Olivier
the most important thing (for me) is that the user can choose the color :-)xnview wrote:Ok, i'll add it, but currently i use an internal color for filename, and text color setting for others labels... Is it a problem if all labels (even filename) are with the same color?Olivier_G wrote:Could you please add "File Name" to the items of the Thumbnail Labels (Default=ON), so that one could decide to show/hide it and choose its position in the labels?
so it is ok by me.
loth
