let me save searches/filters
thire
Post by thire »
I love the search option in XnViewMP, but I hate to redo it every time :-)
My favorit search is "everything better than + one star (ie rated) + sort by time + recursive in all subfolders".
Perhaps others use the search as well very often and find this setting good. Perhaps it could just be saved, so if I click in the filter symbol all this comes up as I did it last time (for this or a different folder).
And BTW: the "better than" is an option under windows, but not under mac. Don't know why...
Thanks for letting me know if you find that this could make sense,
Thomas
Re: let me save searches/filters
but in the search dialog, you can save your search filter
t3mujin
Post by t3mujin »
xnview wrote:but in the search dialog, you can save your search filter
How do I remove those saved searches?
m.Th.
Post by m.Th. »
If you know how to connect directly to the XnView MP SQLite database is easy:
Delete from Search where Label = :mySavedSearch;
However, Pierre need to provide a Delete button for this.
m. Th.
