Default CMYK profile?
Moderators: XnTriq, xnview
RiP
Post by RiP » Sun Oct 20, 2013 8:48 pm
What profile does XnView use to convert CMYK 32bit to RGB 24bit? :?
Re: Default CMYK profile?
Post by xnview » Mon Oct 21, 2013 6:48 am
sRGB
RiP
Post by RiP » Mon Oct 21, 2013 10:36 am
xnview wrote:sRGB
But sRGB isn't for CMYK :? (I know it saves the converted file in sRGB)
For example, Photoshop uses US Web Coated SWOP v2
Post by xnview » Mon Oct 21, 2013 11:38 am
Sorry but i means that converted RGB is sRGB
You can change the profile in Option>ICC
RiP
Post by RiP » Mon Oct 21, 2013 10:13 pm
My problem is that the photo is untagged, without any ICC profile and I can't select anything.
Photoshop shows it different. I need to know what profile XnView uses to convert CMYK to RGB as default :(
Post by xnview » Tue Oct 22, 2013 6:27 am
you can change the default profile in option>ICC
RiP
Post by RiP » Tue Oct 22, 2013 11:21 am
I defined an ICC profile there but it makes no change. Here's the photo:
http://imgbox.com/aczHRPTJ
I still don't know what profile XnView uses to convert CMYK->RGB
Post by xnview » Wed Oct 23, 2013 8:04 am
For conversion CMYK->RGB, XnView doesn't use profile by default.
If you set Default ICC profile 'US Web Coated SWOP v2', the conversion result must be like photoshop...
RiP
Post by RiP » Wed Oct 23, 2013 8:13 pm
xnview wrote:For conversion CMYK->RGB, XnView don't use profile by default
If you set Default ICC profile 'US Web Coated SWOP v2', the conversion must like photoshop...
Already tried but no difference: http://i.imgbox.com/adhU66iH.png
Post by xnview » Thu Oct 24, 2013 7:56 am
could you send me the profile that you use?
fominator
Post by fominator » Fri Apr 07, 2017 11:06 pm
all windows picture viewers display CMYK files correctly accept your program, is it too hard for you to make it display correctly? even PAINT does it correctly
fominator
Post by fominator » Fri Apr 07, 2017 11:08 pm
xnview wrote:For conversion CMYK->RGB, XnView doesn't use profile by default.
this is not true, sorry, it doesn't work
Moderator & Librarian
Post by XnTriq » Sat Apr 22, 2017 11:45 am
This issue has been fixed in version 2.40. Please refer to “Wrong colors: 32bpp jpg gets interpreted as 24bpp” for more information.
