Batch Rename Of Video?
Brans
Post by Brans »
Every time I think I've seen all of the pertinent features in XnViewMP with shell extension I'm proven wrong. This program has a lot of great features. The one I'll be addressing is the feature that allows batch renaming of videos. A couple of weeks ago I accidentally found that feature button which I'm going to post an image of. A few hours ago I installed the latest versions of XnViewMP-win-x64 0.53 and XnView Shell Extension 64 bit 3.4.0.
From what I gather, it only allows batch renaming of wmv and avi files. My question is, is there a way to allow it to read/see and batch rename other types of video files such as mp4, mpeg, flv etc?
XNView Video Button.png (14.81 KiB) Viewed 1358 times
Brans
Re: Batch Rename Of Video?
Post by Brans »
I need to make a couple of corrections. In the image I pointed to in the previous post I should have also circled the pull-down arrow next to it which is what has to be clicked (they are both one in the same) to select video and other options. I also found it does recognize mpeg but not mp4 and flv. Most of the video files I've been dealing with lately are mp4 and wmv. I'm wondering if there is way to enable the other file types maybe via plugin or some other way. Even if there isn't, please let me know. Again thanks Pierre for this great software. :D
XnView Video Optionss.png (16.22 KiB) Viewed 1340 times
Brans
Post by Brans »
Thanks again Pierre!! You are awesome!! I recently installed the latest versions of 64 bit XnViewMP 0.69 and XnView Shell Extension 3.5.0. I'm delightfully pleased that now it recognizes all of the different video types I've come across so far. :D
