XnRetro 1.26: Light effect don't work
More Multi Platform Tools - Windows, MacOSX, Linux
optom
Post by optom »
Hello!
I've just downloaded XnRetro (1.26) for Linux. First of all: I'm using the 32bit version on my Ubuntu 13.04 64bit machine. Unfortunately, your link to the 64bit version is broken.
The main problem: Light effects don't work. Doesn't matter which one I choose, they don't apply to the image. Also, there are no light effect previews in the bottom bar, see screenshot:
Everything else seems to work fine :)
oops66
Re: Light effect don't work
Post by oops66 »
Right, same here.
PS: It will be interesting to also have the set of "kodak filters" or similar "Wratten numbers" effects:
http://en.wikipedia.org/wiki/Wratten_number
http://web.archive.org/web/200910281923 ... ection.htm
XnViewMP Linux X64 - Debian - X64
Moderator & Librarian
oops66 wrote:PS: It will be interesting to also have the set of "kodak filters" or similar "Wratten numbers" effects:
Very interesting! Thanks for the links, oops66 :-)
oops66
Post by oops66 »
You're welcome XnTriq :)
Ok, i can reproduce on ubuntu 12 (or 13) 64bits only if i run the 32bits version of XnRetro, the problem is with jpeg
jpeg files can't be loaded or saved...
oops66
Post by oops66 »
xnview wrote:Ok, i can reproduce on ubuntu 12 (or 13) 64bits only if i run the 32bits version of XnRetro, the problem is with jpeg
Hello Pierre,
Yes, here (Ubuntu 12.04 LTS-X64 + XnRetro 32bits) .jpg files can be loaded but not saved, same for .png file too (for example)... So here: Light effects doesn't work + save doesn't work too ...
PS: FYI: XnRetro is only available in 32bits for the linux version here (linux tgz 32):
http://www.xnview.com/en/xnretro/
http://www.xnview.com/fr/xnretro/
and here too (the link: "linux X64 tgz" does not work):
http://newsgroup.xnview.com/viewtopic.p ... 08#p105008
optom
Post by optom »
oops66 wrote:.jpg files can be loaded but not saved, same for .png file too (for example)...
Well, PNG export works fine for me, doesn't matter if i load jpg or png files, but yes, JPG export fails.
oops66
Post by oops66 »
Right, ... a mistake sorry ... So here: Light effects doesn't work + save doesn't work for jpeg choose only.
PS: I have also tried: XnSketch 1.14 - linux tgz 32 ... and it crashes when I load a jpg or png file.
http://www.xnview.com/fr/xnsketch/
Ok, the solution is to install libjpeg62
sudo apt-get install libjpeg62:i386
oops66
Post by oops66 »
Hello Pierre,
Right, that works here now, thanks.
Melvin
Post by Melvin »
I installed libjpeg62 package but still no light effects and can't save files
OS Ubuntu 13.04 64 bit
Tried on two systems. No success!
HarD
Post by HarD »
Melvin wrote:I installed libjpeg62 package but still no light effects and can't save files
I have same problem
valhallasystems
Post by valhallasystems »
I had the same problems. After studying the thread and installing libjpeg62 (which did not work) I came up with this work around.
1. go to the location of XnRetro. In my case, it is in my home folder, in a folder called "bin". That's where I put all the programs installed as tarballs. Your location will likely differ.
2. go to the folder containing XnRetro and look for the folder "light". Open it.
3. Make a backup of the file "light.xml".
4. All the jpg files in this folder are the overlays for light effects. You need to convert them all to .png format. You can do this manually using your image viewer and Save-as, or if you are adventurous you can use XnConvert. Just changing the extension will not work.
5. Now edit light.xml. Edit the extensions of all the files "Bokeh-2.jpg" "Bokeh-4.jpg" etc to .png (the ones you just created). Save light.xml. That's why you made a back-up.
Now light effects should work. They did for me. Or at least they have so far, I have not yet finished my conversions, but the ones I have done have worked as expected.
Its all tied up in the way XnRetro handles .jpg files. It appears to open .jpg files for editing, but will not save them, you have to save your finished product as a png. Similarly it appears to expect its overlays as .png files. If you look at the folders "vignette" and "frame" you will see that the overlays in those are all .pngs, because .png files support transparencies. I suspect the overlay engine in XnRetro expects transparancies and will thus not read .jpgs since they do not support transparencies. Only Pierre can answer this definitively.
valhallasystems wrote:I had the same problems. After studying the thread and installing libjpeg62 (which did not work) I came up with this work around.
and no problem to save/load jpeg files?
valhallasystems
Good question:
First, I'm using Mint 17, 64bit, Cinnamon DM
Now to answer your question. Now that I've "fixed" LIGHT in XnRetro and have installed libjpeg62, I note the following:
I. Xnretro reads .jpg files to edit (just about everything I have is in that format). It would do that before libjpeg62 was installed. However, as noted earlier it will not read the .jpg files containing the light overlays. They had to be converted to .png to work.
2. XnRetro will not save .jpg or .jpeg files, even if JPG is flagged in the File Save dialogue box. No files appear in the target folder. No error messages appear.
3. XnRetro will save .png files, but PNG needs to be flagged in the File Save Dialogue box and the extension on the File name line needs to be changed to .png
4. XnRetro will save a file called .jpg if that is the name on the File name line and PGN is flagged in the File Save dialogue box. The output file is in the .png format but the extension is .jpg. As a result, my file system can't handle the file, unless I manually change the extension to .png. Then the file system will handle and properly display the file.
Hope this clarifies.
