Thumbnails for PSD-files with alpha-channel
hdamm
Post by hdamm »
Hi.
I just installed the latest version (v2.0 Apr. 9 2013).
I have a lot Photoshop (PSD) files that contain an alpha channel. In xnview the thumbnail show only the alpha-channel (instead of the embedded thumbnail), which is not quite helpful :?
Photoshop files without alpha channel do not have any problem.
Regards
H.Damm
Re: Thumbnails for PSD-files with alpha-channel
hi,
could you send me a sample?
hdamm
Post by hdamm »
xnview wrote:hi,
Pierre: what kind of sample would you like to have? Screenshot of xnview?
File :)
ok, i have it, in thumbnail i have RGB merged with alpha, not you?
hdamm
Post by hdamm »
xnview wrote:ok, i have it, in thumbnail i have RGB merged with alpha, not you?
Well – to me it looks like alpha only …
could you post a screenshot?
hdamm
Post by hdamm »
xnview wrote:could you post a screenshot?
Here you are:
If you open the file, you have exactly the same
