Xpvr Plugin - Support for pvr file types
Xpvr - plugin for viewing some PowerVR format types.
Supported PVR types: PVRTCI 2bpp RGB, PVRTCI 2bpp RGBA, PVRTCI 4bpp RGB, PVRTCI 4bpp RGBA, ETC1, BC1(DXT1), BC2(DXT3), BC3(DXT5), RGBA4444, RGBA5551, RGBA8888, RGB565, RGB888, LA88, L8.
Download v2015.04.22
Unpack Xpvr.usr from the archive into '..\XnView\PlugIns' folder.
Re: Xpvr Plugin - Support for pvr file types
Thank you very much, Arty, for your effort in providing an XnView plug-in for your PowerVR Graphics!
Ahem, shouldn't the user-developed plug-in with extension .usr be listed in the "Plugins user" section?xnview wrote:Thanks, i've added HERE
New version:
[+] Added support for uncompressed formats: RGBA4444, RGBA5551, RGB888, RGB565, RGB888, LA88, L8.
[*] Fixed viewing PVR files with PVRTextureHeaderV3.
[*] Fixed memory leak with uncompressed formats.
Supported PVR types: PVRTCI 2bpp RGB, PVRTCI 2bpp RGBA, PVRTCI 4bpp RGB, PVRTCI 4bpp RGBA, RGBA4444, RGBA5551, RGBA8888, RGB565, RGB888, LA88, L8.
New version 2014.01.09:
[+] Added support for ETC1.
[*] More than 2x speed-up for decoding large images with RGBA4444, RGBA5551 and RGB565 formats (using CLUT on large images).
[*] Small speed-up by using PGO.
[*] Some memory usage optimizations.
Hi ArtyArty wrote:New version 2014.01.09:
I would love to install your plugin on mac. Any chance you have a mac friendly zip version?
Thanks
Hi Sal.
Sorry, there is only Windows SDK for XnView, so I can't make mac version of plugin.
New version 2014.08.28:
[!] Fixed crash when decoding some ETC1 textures (width or height is not divisible by 4).
[+] Added support for BC1(DXT1), BC2(DXT3), BC3(DXT5).
I'm running XnViewMP, but the plugin doesn't appear to generate thumbnails for the two "lena_*" images in the \test\ subfolder. Am I doing something wrong?
Thanks!!
Thanks!!
Hi.prouticus wrote:I'm running XnViewMP, but the plugin doesn't appear to generate thumbnails for the two "lena_*" images in the \test\ subfolder. Am I doing something wrong?
This is because this plugin is developed only for XnView not for XnViewMP version.
New version: 2015.03.10
[+] Added support for texture flip (x|y) flags in PVR header meta-data.
[+] Added support for different file extensions of PVR images (XnView v2.32 or later).
New version: 2015.04.22
[!] Fixed possible crash when trying to recognize PVR in file with different extension.
