Selection ratio: Problem with "Same as image"
When using a selection ratio which is same as image (Edit > Selection Ratio > Same as image or key 'D'), and then swapping selection ratio by pressing Tab key, the ratio will not swap. Instead, the selection just grows. (Bug)
Re: Selection ratio: Problem with "Same as image"
helmut wrote:When using a selection ratio which is same as image (Edit > Selection Ratio > Same as image or key 'D'), and then swapping selection ratio by pressing Tab key, the ratio will not swap. Instead, the selection just grows. (Bug)
Right a bug
efxgfx
Swap width/height selection ratio
Post by efxgfx »
The problem occurs also when you have a custom selection ratio set and want to switch width and height around. I teach others in the use of XnView so I had to find a workaround. One way is to create a custom selectin SIZE that is the opposite orientation (vertical) from the custom selection RATIO (horizontal).
Because not everybody tinkers with a program's settings, I preset settings in my friends' XnView installation by including a copy of xnview.ini where userselratioX and userselratioY and selectionwidth selectionheight are set.
When choosing a HORIZONTAL selection ratio, we choose the custom selection ratio. When choosing a VERTICAL selection ratio of the same ratio, we choose the custom selection size.
At least until the next version...
