Slide-show with transition effects?
Locked
Y.B.
Post by Y.B. »
I'm only think to use XnView and there is a question: does XnView
slide-show support transition effects?
Thank you,
Yuri.
Transition effects in XnView DeLuxe, only
In XnView 1.66, transition effects are not supported, yet. Not sure what Pierre's plans are regarding this.
XnView DeLuxe 2.0, the commercial version of XnView supports about 30 transitions (see http://www.xzeos.net/index_uk.htm for a Trial version).
Locked
