some little bugs :)
peil
some little bugs :)
Post by peil »
when image is under 100% and when moving, the image resize 100% during cliking
moving the size of thumbnails in browser make xnview crashing
some export formats doesn't work correctly at certain settings ( like minimal quality/maximal quality)
see the browser window appearing before the full screen when launchin an image
some icons missing or shifted in the Dark theme (guess it is because not finished yet)
ps : could you add the plastic black theme and clean black theme.
..make the histogram fit the windows and AA it (not important at all ;) )
bye:)
peil
Re: some little bugs :)
Post by peil »
i add that it would bee cool in full screen mode that, when cliking outside the image, the windowed mode appears in the tab of the image
in 0.53 you have to double clik, and it is on the browser tab you land by default.
that's it.
peil
Post by peil »
double clik on a pdf file in the browser makes xnview crash
enhance color window previews are not in the right size
sometimes, quite slow at first launching
peil
Post by peil »
up/down keys set in next/previous file still continues to scroll verticaly
when moving histogram window, some pixel lines from the histogram window borders stays on the image
histogram displays false information (in comparation with the histogram of photoshop) : the curve tend to be totally down fore a given brightness when the brightness is not zero at all.
peil
Post by peil »
when double clicking on a .hdr file, xnview dones'nt open the file but opens the last image opened in the previous use of xnv.
to be able to read the hdri, i have to open a .jpg file (by example) in the same folder and then, landing on the hdr file by clicking next picture.
peil
Post by peil »
On full screen (perhaps on other modes, did'nt try...), when i look in the tab "exif tool", it is very long to load (up to 10 seconds) and during this time xnview is frozen.
the other "EXIF" tab is a lot faster even if a little less detailed. (by the way why is there 2 exifs tabs?)
cant wait to see the upcoming linux version ;)
jeonry
Post by jeonry »
Hey peil, your not alone with this, I was getting the xnview crashing each time I was altering the thumbnails, was driving me nuts
Henry Nioxin shampoo is good, read nioxin reviews , to find out about nioxin shampoo , here are good nioxin shampoo reviews. Check it out
Please make a topic per bug/request
