Setup assigns filetypes with wrong path
Andreas
Post by Andreas »
Hi Pierre
First of all your software is an excellent piece. I like it.
In the actual version (1.80) there's a small bug in the setup procedure. It assigns most of the filetypes (e.g. .JPG) to the path "C:\Programme\XnView" instead of "C:\Programme\XnView\XnView.exe".
After installation I used the menu to reassign them and it worked fine. It happened with the file "XnView-win-full.exe".
Kind regards,
Andreas
Re: Setup assigns filetypes with wrong path
Andreas wrote:First of all your software is an excellent piece. I like it.
Thanks, and i check this problem
