XnSketch 1.00 for windows is available HERE
With XnView Sketch you can easily turn your photos into cartoon or sketch images.
Features:
★ 18 different effects (black strokes, white strokes, pastel, pencil sketch, colored sketch, ...)
★ Edge strength, and opacity adjustement
★ Contrast, brightness, saturation adjustement
★ Save or share the result
MacOSX version is available HERE
Android version is available HERE
XnSketch 1.00
XnSketch 1.00
Re: XnSketch 1.14
Tried using the Windows version of 1.14 XnSketch. There are some interesting effects, particularly "Hope," but it reduces the size of the image during save and so the final results are rendered differently from what's on screen and the image is no longer useable. Another big problem is there are no controls for JPG quality. A nice enhancement I would love to see is a transparency control to the underlying original image. This would effectively limit the intensity of the effect of the sketch on the original. - SF
Re: XnSketch 1.14
ok, could you send me the original file and the result, please?samfeinsilver wrote:Tried using the Windows version of 1.14 XnSketch. There are some interesting effects, particularly "Hope," but it reduces the size of the image during save and so the final results are rendered differently from what's on screen and the image is no longer useable. Another big problem is there are no controls for JPG quality. A nice enhancement I would love to see is a transparency control to the underlying original image. This would effectively limit the intensity of the effect of the sketch on the original. - SF
Re: XnSketch 1.00
Here are the source and result files (attached); The source has been re-filed to get the file size under the 256K limit for upload to this discussion board. I hope this helps. It's an interesting little application. -- SF
Re: XnSketch 1.00
Thanks, I was using the "File" pull down menu's and didn't notice the options available under the icon.
- Moderator & Librarian
Re: XnSketch v1.18
The Windows and Linux editions of XnSketch have been updated to version 1.18 on 25/Apr/2016:
Re: XnSketch 1.00 - possible bug?
Or maybe just bad file handling.
First - nice work, it's a great little program.
The bug:
The saving - you can chose between jpg and png, great.
But if you start with a jpg and it's set to save as png then it will save as NAMED jpg, CONTENTS png (when I open the picture in irfanView it complains and says "input file is actually png file with wrong extension, shall i correct it?"
If you manually change the save as to the other and back again (set it to jpg then back to png) then the save extension corrects itself.
It's not a killing bug, juts a little irritating.
The bug:
