Non-translatable strings in XnConvert
Sometimes, new strings are added which are non-translatable:
- There is no string available in the translation tool.
- Translators can translate them, but translation is not displayed in XnConvert.
Translators, please post non-translatable strings, here.
Re: Non-translatable strings in XnConvert
XnConvert 1.5b:
- "Settings" (Tab title)
- "Check for program updates"
- "Monthly"
- "Weekly"
- "Daily"
- "Never"
- "Add 'Convert with XnConvert' to context menu"
- "Save action list at exiting"
- "Monthly"
- "Weekly"
- "Daily"
- "Never"
If you have an updated language file, please send me it, i'll update it
O.k., I'll send you a German language file occassionally.xnview wrote:If you have an updated language file, please send me it, i'll update it
Hi Pierre and Helmut
I just downloaded XnConvert 1.50b, and there are many strings not translated to German. The language-file is
Peter
"qt_de.qm 325046 26.01.2012 22:47:44 -a--"
I've updated the German language file on 9th Aug.. Pierre, could you please check?Peter2 wrote:I just downloaded XnConvert 1.50b, and there are many strings not translated to German. The language-file isCode: Select all
XnConvert - untranslated
I spotted two strings in XnConvert v1.55 which may be untranslated.
Output - Destination file name - options pop-up
See attached image.
Stephan
See attached image.
Stephan
- Attachments
- Two strings possibly untranslated
- XnConvert-untranslated.png (33.42 KiB) Viewed 32484 times
Re: XnConvert - untranslated
Strange, you have translated them... i'll checkStephanP wrote:I spotted two strings in XnConvert v1.55 which may be untranslated.
Old problem, also in other languages:xnview wrote:Strange, you have translated them... i'll checkStephanP wrote:I spotted two strings in XnConvert v1.55 which may be untranslated.
http://newsgroup.xnview.com/viewtopic.p ... tor#p92363
Peter
