Non translatable strings
Re: Non translatable strings
'Uncolored' is not available for translation
also its better to unify image/photo → file (topic)
- MenuBrowser
##label## (move to next image)
- MenuView
##label## (move to next photo)
nope, its:
just change Language to any national after unzipping clean version
[ColorLabel]
label_0=Uncolored
In this case, you need to remove label_* from .iniuser0 wrote: Sat May 04, 2024 12:30 pm nope, its:just change Language to any national after unzipping clean versionCode: Select all
[ColorLabel] label_0=Uncolored
ah, I see what you did here..
Color labels are generated (depending on selected language) and saved on the first run
and never changes automatically since than, only via Settings>Metadata>Labels
this approach is fine for labels 1-9, but I think lable0 should change each time user changes app language, since it is 'service', non-editable label
- Moderator & Librarian
My bug report: Mixed language
oops, looks like I missed it
- "Auto hide" hint in Fullscreen mode
also, I would rename it "Pin"
- Categories/Category Sets - [Create New]
