Non translatable strings
Translation of On-Screen texts of XnView MP and XnConvert
Moderators: XnTriq, xnview
Re: Non translatable strings
xnview wrote:
helmut wrote: Message box: Do you want to save your session? Yes / No
i have ja/nein
Strange.
xnview wrote:x64 version zip or setup?
x64 ZIP version of XnView 0.83 running on Windows 7 (VMWare machine). The same on Windows XP.
Using original xnview_de.qm or new release of xnview_de.qm created by Linguist makes no difference.
i've tried on win 7 x64, with the ZIP package, and i have german...
do you have qt_de.qm?
xnview wrote:i've tried on win 7 x64, with the ZIP package, and i have german...
Sorry for the late reply. Yes, in subfolder ..\language\ I have
a. xnview_de.qm
b. qt_de.qm
c. exif_de.lng
I've tried XnView 0.76 and 0.81; the standard buttons like Yes/No/Cancel are always in English.
The important file is qt_de.qm, really strange i don't understand why it works here. Someone else can test too?
xnview wrote:The important file is qt_de.qm, really strange i don't understand why it works here. Someone else can test too?
I've justed tried XnView MP 0.83 (ZIP, 64bit) on a different system (Windows 7) and there the buttons are displayed in German. Must have something to do with the Windows system. Hmm.
herb
Post by herb »
Hello Pierre,
I work with XnViewMP 0.87 64bit.
The string "Enable Catalog" in Settings - Catalog cannot be translated. See attached screenshot.
In file xnview_de.ts -08.07.2017 - does not have the corresponding entry for a translation.
Best regards
Herb
herb
Post by herb »
Hello Pierre,
I installed XnViewMP 0.93 and I have seen that on Tools -> Settings -> View the words "Selection", "Rule of thirds", "Normal" and "Phi grid" are not translated.
Also the latest language file xnview_de.ts does not contain corresponding entries.
Best regards
Herb
In XnView 0.94 beta 1 there are various non-translatable strings:
Menu: Tools > Capture...
Menu: Image > Edit Colormap...
Menu: Edit > Import clipboard
helmut wrote: Wed Sep 25, 2019 8:11 pm Menu: Tools > Capture...
You have them in MenuGlobal
right
Thank you, Pierre for your prompt reply.
xnview wrote: Thu Sep 26, 2019 6:54 am
Right, but in the menu always the English label is displayed.
Three more labels in 0.94 beta2 which are always displayed in English.
• Image mode, menu item Edit > Edit IPTC/XMP
• Browser mode, menu item File > Select Twain source
• Browser mode, menu item File > Select Twain scan
helmut wrote: Sun Sep 29, 2019 1:19 pm Three more labels in 0.94 beta2 which are always displayed in English.
yes right
In XnView MP 0.94 Herb found some non-translatable strings:
Browser | Tools » Meta data » Transfer... | Button "Add>>"
In the dialog "Transfer Meta data" when pressing "Add>>" one can see many non-translated strings. And currently there is no way to translate these. Most of these strings have been translated already - would be good if the same strings would be used here without translating them, again.
Please note that the button "Clear all" in that dialog is never active which seems to be a bug. :bug:
helmut wrote: Mon Nov 18, 2019 9:49 pm In XnView MP 0.94 Herb found some non-translatable strings:
right, i'll change that...
0.96:
Title "Session" of message box with message "Your previous session contains many loaded images, this can cause a slowdown!" seems to be non-translatable.
