Non translatable strings
Translation of On-Screen texts of XnView MP and XnConvert
tmksStyle
MP 0.38 Win:Information Pane does not been translated
Post by tmksStyle »
Information pane does not been translated. :(
"Properties" tab is OK, but "EXIF" "ExifTool" and "Categories" tabs are not translated. They are displayed in English language.
I use in the Japanese environment.
Are the other countries all right?
mantis3d
Re: MP 0.38 Win:Information Pane does not been translated
Post by mantis3d »
Me too.
I use in Chinese.
sprayer
Post by sprayer »
Hi, Pierre.
I can't apply translation to this phrase:
Rotate image based on EXIF orientation
Image data - from menu Copy to clipboard
Filename and path - from menu Copy to clipboard
Filename - from menu Copy to clipboard
Path- from menu Copy to clipboard
Clear all file items in 'Input' tab - different phrase in program and .ts? and can't apply too
Format settings - can't find for title menu
Ignore read errors - can't find for dialog Format settings - Read
Keep EXIF - can't find for dialog Format settings - Write
Keep IPTC - can't find for dialog Format settings - Write
Keep XMP - can't find for dialog Format settings - Write
Keep ICC profile - can't find for dialog Format settings - Write
Re: Non translatable strings
In 0.56 following strings seem to be non-translatable:
Display ratings (Tools > Options | Browser)
Display all graphic formats (Tools > Options | General)
Hide scrollbars (Tools > Options | View)
Hide scrollbars (Tools > Options | Fullscreen)
Hide toolbar (Tools > Options | Fullscreen)
Serezha
Post by Serezha »
0.69
Filter - Global
-Current folder
-Current folder (recursive)
Right mouse button on photo - Important (move to...-no translate), Work (move to...-no translate) and etc.
In 0.75 beta following strings seem to be non-translatable:
"Cancel" - Cancel button in dialogs
"Close" - Close button in dialogs
"<Colour label> - move to next file" - Menu "Colour label"
"User (System)" - First start dialog
"Program (System)" - First start dialog
"Custom" - First start dialog
"<Autodetect>" - First start dialog
helmut wrote: "Cancel" - Cancel button in dialogs
a problem in the package
right
mantis3d
Post by mantis3d »
“Mouse wheel + CTRL" - (Settings>Interface>Mouse)
XnView MP 0.83:
"Cancel" buttons are English, again.
Non-translatable strings:
"Attach preview panel"
"Detach preview panel"
herb
Post by herb »
Hello Pierre,
as Helmut stated, "Attach preview panel" and "Detach preview panel" cannot be translated into foreign languages.
For me, another possibility would be to remove these context menu entries completely,
because menu "View" -> "Info Pane" -> "Preview as tab" also does the "Attach"/"Detach" of preview pane.
Best regards
Herb
helmut wrote:XnView MP 0.83:
and not in 0.82?
and not in 0.82?
I have never tried XnView 0.82 so I cannot say. In 0.81 the buttons were also in English.
In 0.83 it's not just the "Cancel" button but also the other buttons like "Save", "Yes", "No".
helmut wrote: In 0.83 it's not just the "Cancel" button but also the other buttons like "Save", "Yes", "No".
on which dialogs?
on which dialogs?
The question should be vice versa: On which dialog is it correct? ;-) From what I can see the buttons are always in English.
Some examples:
Message box: Do you want to save your changes? Save / No / Cancel
Message box: Do you want to save your session? Yes / No
"Tools > Settings" dialog
"Image > Resize" dialog
helmut wrote: Message box: Do you want to save your session? Yes / No
i have ja/nein
Ok/Abbrechen
x64 version zip or setup?
