Sequential Numbering to Start from 1 for each (sub)folder
EuM_Expert
Post by EuM_Expert »
I am quite new to XnConvert - many thanks for that great tool!
My images are residing in folders and subfolders.
The renaming in #Output# is set to {Folder name}_##.
Works great, except that I would want to have the sequential number reset to 1 for each new subfolder.
Is that possible? And how to set it up?
Thx!
Re: Sequential Numbering to Start from 1 for each (sub)folde
yes # is global, i need to add one for each folder...
xnview in [url=http://newsgroup.xnview.com/viewtopic.php?f=79&t=26263]XnConvert 1.50 beta[/url] wrote:...
Changelog:
* $ to use as numeric enumerator per folder
Gator38
Re: Sequential Numbering to Start from 1 for each (sub)folder
Post by Gator38 »
I'm using the last version of xnviewMP (1.7.1 64 bits Apr 8 2024).
I use "Import and Sort" function.
It seems that the function "# enumerator per folder" doesn't works. When I choose this option the numbering continues at each new folder.
I would like that the first file of each folder start by 1.
I tried the $ but it doesn't works.
Do you have an idea to solve my problem?
Regards.
I move this post on the xnviewMP forum:
viewtopic.php?f=62&t=47294&p=198318&hil ... er#p198318
Regards.
