XnRetro
More Multi Platform Tools - Windows, MacOSX, Linux
Re: XnView Retro
Post by xnview » Wed Sep 12, 2012 1:49 pm
BillBo wrote:The Windows download links at the
top of the topic work OK, but the
MacOS do not.
Right, only available with Apple Store
I just downloaded the 32-bit version
1.1.0.0. Is there one for 64-bit?
Soon
Moderator & Librarian
Re: XnView Retro
Post by XnTriq » Mon Sep 17, 2012 6:00 pm
XnTriq wrote:Pierre, would it be possible to preserve transparency around a frame in the output?
Added in v1.12 :D
XnTriq wrote:File » Save » BMP - Windows Bitmap produces PNGs :bug:
Fixed in v1.12 :bugfixed:
(Output can be saved in PNG and JPEG format.)
xnview wrote:[...] i've fixed the order of layers [...]
Confirmed fix for v1.12 :bugfixed:
xnview wrote:@XnTriq: For the border line, i'll check...
Thanks, Pierre!
I've updated my samples, because the format of frames.xml has slighly changed in v1.12.
Has ratio="true" been added due to John's request?
White background
Transparent background
[color=green]\frame\frames.xml[/color] wrote:
<item title="Golden Frame #1" file="gold-frame-psd20632_1.png" top="121" right="125" bottom="122" left="125" />
<item title="Golden Frame #2" file="gold-frame-psd20632_2.png" top="121" right="125" bottom="122" left="125" />
(Source: Official PSDs)
Re: XnView Retro
Post by XnTriq » Fri Nov 16, 2012 10:15 pm
Fixed in XnRetro 1.20 :bugfixed:
Re: XnView Retro
Post by XnTriq » Sun Nov 18, 2012 4:00 pm
Lighting effect and vignette exceed the area specified for the photo when I use my custom frame with transparent border and Square output is activated :bug:
[ z00m ]
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=106616#p106616]XnView Retro[/url]) wrote:
Re: XnView Retro
Post by XnTriq » Mon Nov 19, 2012 4:45 am
I'd like to be able to move the photo around inside the frame with the mouse and place it back to a centered position with a reset button.
Re: XnView Retro
Post by helmut » Tue Nov 20, 2012 6:54 pm
XnTriq wrote:I'd like to be able to move the photo around inside the frame with the mouse and place it back to a centered position with a reset button.
+1
Letting the user zoom the image and move the image around to choose a specific area of the image would make framing even more flexible.
vandario
Re: XnView Retro
Post by vandario » Tue Jan 08, 2013 8:05 pm
Hi there!
I would like to thank you for creating and distribuiting xnview Retro. It is really a great app! I use it with Android and Windows 8.
I just have a comment to do.
I am not able to share pics with Flickr because when it opens the flickr web page nothing happened. I tried with Chrome, IE and Firefox with same results. (Windows 8)
Any Idea?
Thanks!
Dario
Re: XnView Retro
Post by xnview » Fri Jan 11, 2013 10:39 am
vandario wrote: I just have a comment to do.
You have not a dialog box from XnRetro, and your default internet browser is not opened?
vandario
Re: XnView Retro
Post by vandario » Fri Jan 11, 2013 4:51 pm
Yes, it open my default browser but after asking me my flickr password it remains a white page for ever.. I tried to copy the link into two other browsers with no success..
salvadhor
Re: XnView Retro
Post by salvadhor » Tue Mar 26, 2013 2:47 pm
Is it possible to get Linux build of the newest XnRetro?
HarD
Re: XnView Retro
Post by HarD » Wed Oct 16, 2013 7:09 am
Cool work on Linux
But i have question how i can help translate or translate it to Russian
And maybe you can support themes for icons (or support system icons)
