XnView portable?
ghost zero
XnView portable?
Post by ghost zero »
Is there a portable version of XnView?
Re: XnView portable?
ghost zero wrote:Is there a portable version of XnView?
you can easily make a portable version (use xnview folder for .ini)
ghost zero
is there a portable version for download? one that requires no install?
Peter2
Post by Peter2 »
ghost zero wrote:is there a portable version for download? one that requires no install?
XnView does not need a real "install" - it is a simple "copy files to target". But you can use the "ZIP"-files from download page. Unzip it to where ever you want - that's all.
Peter
ghost zero
if i use the zip version and run it from a usb, does it leave any leftovers on the computer?
Peter2
Post by Peter2 »
You have to consider where the settings of XnView (and its plugins) are stored. You can select it in the "Options": Registry, program folder, personal folder ...
Peter
Zottt
Post by Zottt »
Please read here.
