0.50 Linux 32bit (Opensuse12.1) LENSID Problem
XnviewSuperFan
Post by XnviewSuperFan »
In INFORMATION (full view)
META:LensID brings no results.
Did'nt find a workaround as EXIF:Short Focal or EXIF:Long Focal or others dont work either.
I know, that with Properties you have results, but not with the INFORMATION feature.
Kamera: Canon 5dMII diverse optics.
Thanks for your great work, Pierre.
Re: 0.50 Linux 32bit (Opensuse12.1) LENSID Problem
XnviewSuperFan
Thanks for your answer, Pierre.
Here a Sample file.
Ok, i'll fix the problem of META:LensID in 0.51
