XnView crashing with ecw files
davidm
Post by davidm »
XnView appears very unstable when trying to work with ecw files. I have 1.98.8 installed with the latest plugin files downloaded and installed. XnView crashes repeatedly on trying to open an ecw file but occasionally does succeed in opening it. Then if I try to go to adjust the levels on the file, as soon as I choose this option it crashes. Is the current version compatible with the ecw plugin files offered for download?
Re: XnView crashing with ecw files
Which size in pixels?
davidm
Post by davidm »
I am trying it on a file 1.06Mb in size that is 12000x12000 in pixels
davidm wrote:I am trying it on a file 1.06Mb in size that is 12000x12000 in pixels
Perhaps too big, when you try to load it could you check the memory used?
FrontierDK
Post by FrontierDK »
I'm also trying to open a .ECW file - but when trying to open in XNview, I get a "format of the file 2013.ecw could not be determined".
I just installed the extended version which should have .ECW support...but it doesn't appear to be so?!?
in plugins folder?
