ok on windows 7 x64, error on w2008 x64
gennarokoala
Post by gennarokoala »
I'm doing some test with gflax version 2.82 because version 3.40 give me error when I try to register the dll
I'm implementing on a asp.net site (in vb.net)
Windows 7 x64 (with IIS7) gflax 2.82 and ghostscript 9.0.5 is ok:
Register the dll, add the reference to the web site, run the test page where I create a jpeg from first page of a pdf with this code
        Dim g As New GflAx.GflAxClass()
        g.EpsDpi = 72
        g.Page = 1
        g.LoadBitmap(file)
        g.Resize(90, 120)
        g.SaveFormat = GflAx.AX_SaveFormats.AX_JPEG
        g.SaveJPEGQuality = 100
        g.SaveBitmap(output_file)
All works perfectly
On the production server I installed the same version of Ghostscript and registered the same version of gflax (2.82), but when I run the test page I get the following error:
Unknown format
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Runtime.InteropServices.COMException: Unknown format
if someone could help me I would be very happy
PS: Sorry for my poor english
Re: ok on windows 7 x64, error on w2008 x64
Problem with PDF was in 2.82
You can't register 3.40?
gennarokoala
when I try to register the dll is 3.40 i get error (i translate error from italian to english):
not load the module "Test.dll"
Can not find the specified module
I get error when try to register 3.40 on windows 7 and windows 2008
Version 2.82 on windows 7 works properly, "InteropServices.COMException: Unknown format" is only on Windows 2008
Do you have installed Visual2008 CRT dll?
gennarokoala
In control panel i see:
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161
Is this ?
I see also:
Microsoft Visual C++ 2005 Redistributable
Microsoft Visual C++ 2010 x86 Runtime - 10.0.40219
Microsoft Visual C++ 2010 x64 Runtime - 10.0.40219
Could you send me your email by PM
