Handling DivX 6.0 Playback problems
Frequently Asked Questions regarding XnView (including Answers)
ckit
Post by ckit »
XnView 1.80 fails to play DivX 5 "packed bitstream" AVI files when DivX 6.0 codec is installed.
This will probably be fixed in a later version of XnView.
- Zoom Player 4.03 also fails to play DivX 5 "packed bitstream" AVI files when DivX 6.0 codec is installed.
- Media Player Classic 6.4.8.4 has no problems playing DivX 5 "packed bitstream" AVI files with DivX 6.0 codec installed.
- Windows Media Player 9 instantly closes itself when trying to play DivX 5 "packed bitstream" AVI files with DivX 6.0 installed.
Step-by-Step Solution:
DivX Labs recommends setting DivX 6 Decoder to "Automatic Deblocking" only when using editing apps with DivX 6.
1. Open VirtualDub -> File Menu -> Open your DivX 5 "packed bitstream" AVI
2. Video Menu -> enable Full prcessing mode
3. Video Menu -> Compression... -> DivX 6.0 Codec (leave as default settings)
4. Audio Menu -> enable Direct Stream Copy
5. File Menu -< Save As -> Whatever filename you want
6. Click Save and Wait for the new non-packed AVI to be created :)
VirtualDub (freeware) can be downloaded here - http://www.virtualdub.org/
Notes:
Don't worry if the FourCC for the new AVI file still says DivX 5.0, as long as it plays in XnView it really doesn't matter.
Hacker
Post by Hacker »
It should be noted that such recompression decreases quality.
Roman
ckit
Post by ckit »
I just uninstalled DivX 6.0 and re-installed DivX 5.2.1
DivX 6 is complete garbage, thanks to divxsm.exe!
Foobar2000, PhotoFiltre, Vivaldi Browser (standalone), Windows Eleven Pro x64 22H2 (MPO disabled), XnView MP and XYplorer Pro
ckv
Post by ckv »
ckit wrote:I just uninstalled DivX 6.0 and re-installed DivX 5.2.1
And sh*t, totally.
ckit
Post by ckit »
No Problems with DivX 6 now :)
ckit
Post by ckit »
My new approach: just use FFDShow, turn off postprocessing and turn on sharpen :)
Olivier_G
Post by Olivier_G »
I kept DivX 5.2.1 until the recent 6.1.1 due to a bidirectional precision playback issue in VirtualDub with 6 (keyframe was not the frame actually displayed). It's fine now...
I also noticed some coloring artefacts with DivX6.1.1 videos when using ffdshow20051129 (in MPC). Therefore, I now use Divx decoder for all DivX content...
Olivier
PS: my only issue now is slow thumbnails creation +change of focus when creating thumbnails of Divx videos with XnView... not a big deal thanks to Cache!
