When you select "Same as Image" ratio, create a selection and Swap width & heigth:
A. if you immediately create a new selection, it will keep the same Orientation as the previous one = OK.
B. if you click (LMB) somewhere else in the picture first, and create a new selection, it's Orientation will revert back to the image's one.
They both should be consistant (ie: keep the same orientation, just like in A).
Olivier
XnView 1.80 <x>
RC6: Selection Swap with "Same as Image" ratio can
Re: RC6: Selection Swap with "Same as Image" ratio
RightOlivier_G wrote:When you select "Same as Image" ratio, create a selection and Swap width & heigth:
