unable to load Bitmap-file (xx.bmp) if one Dimension exeeds the limit of GFL_UINT16.
Using GFL_VERSION 3.40 (64 bit) (Windows 7)
If Width x Height = 65532 x 2000 gflGetFileInformation(..) works OK.
If Width x Height = 65536 x 2000 and 'file' is a bmp-File.
gflGetFileInformation( file, -1, &info ) returns the errorcode [Error to open file]
gflLoadBitmap returns the same error
Loading a xx.tif file of that size, gflLoadBitmap works OK an it's possible to
save the loaded 'bitmap' using gflSaveBitmap( dstfilename, bitmap, &save_option ) as
a xxx.bmp file !!! and that xxx.bmp file is OK !!
Windows7 viewer can display it.
NConvert6.05 and Xnview1.98.8 have similar Problems to open that xxx.bmp file
Regards Reinhard
unable to load xx.bmp if Width > 65532
Re: unable to load xx.bmp if Width > 65532
Yes, i'm not sure that BMP file can have width > 0xffff
