0.39 win-x86: Crash on any unsaved 'Captures' in Fullscreen
budz45
Post by budz45 »
There is a program crash and obvious reason for this program crash when Importing a picture from "Import Clipboard" and then going into Fullscreen view.
1.) download & extract a clean XnView MP 0.39 (x86)
2.) Create an 'xnview.ini' in the same extracted program folder(s)
3.) Run program, and "Import Clipboard" a picture
4.) Now enter "Fullscreen" view
5.) In Fullscreen, move your mouse cursor to the 'top' OR to the far 'left' of the screen corner in fullscreen
6.) Instant program CRASH
My reason: Because in Fullscreen XnView MP 'thinks' that the clipboard picture being viewed is a regular local image file.
*Same program Crash Bug Reproduce occurs with the XnView MP "Screen Capture" and "Web Capture" too*
Similarly if I "Import Clipboard" a picture, hit the "Spotlight" command and the go in to "Fullscreen" (with 'Spotlight' toolbar displayed) once in fullscreen I try to change the values on the "Spotlight" toolbar only to experience the same crash as the :bug: reproduce above. So "Spotlight" and "Crop" toolbars in Fullscreen need to work together with the thumbnail floating-view and not cross-interfere with each other.
Thanks for reading
marsh
Re: 0.39 win-x86: Crash with "Import Clipboard" & Fullscreen
Post by marsh »
Same problem with captured image.
budz45
Post by budz45 »
marsh wrote:Same problem with captured image.
Yes you mean unsaved xnview mp "Screen Capture" image in Fullscreen too, thanks. I have updated the main first post above with that info for Pierre to see, thanks marsh.
This program Crash is only happening because of the "Floating views" in Fullscreen such as the "properties" and "directory thumbnail-strip" being accessed when they should not be accessed for unsaved Import Clipboard/Screen Capture/Web Capture picture's. Thanks.
Please check XnViewMP 0.48
budz45
Post by budz45 »
xnview wrote:Please check XnViewMP 0.48
Thank you. Fixed in XnViewMP 0.48 :) :P
