Crash on start XnView MP 0.39 Linux Arch
euproko
Post by euproko »
Hi.
I use Arch 32b and Xfce 4.8
This log is displayed in console:
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1280 800
w.init
XNVIEW SIZE 1280 800
########### BrowserWindow :: BrowserWindow
MENU install : 98fb3e8
### ThumbLoaderThread :: stop()
QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
########### BrowserWindow :: ok create (640 480)
#### VISBILITY: 98f9f68 0
BrowserWindow :: changeVisibility()
BrowserWindow :: updateMenu()
#### VISBILITY: 98f9f68 1
########### BrowserWindow :: restoreState (1280 800)
BrowserWindow :: restoreState => 1280 800
=> 1018 687
BrowserWindow :: restoreState ok => 1018 687
XNVIEW SIZE ok
## XNVIEW RESIZE : 1280 800
## MyTabWidget :: resizeEvent : 1280 800
## BROWSER RESIZE: 1044 561
I/O error : No such file or directory
/usr/share/mime/inode/directory.xml:1: parser error : Extra content at the end of the document
/usr/bin/xnviewmp: line 5: 2954 Ошибка сегментирования "$dirname"/xnview "$@"
Thanks
P.S: Forgot to say earlier, it worked fine!
Re: Crash on start XnView MP 0.39 Linux Arch
You have not updated your system?
euproko
Post by euproko »
xnview wrote:You have not updated your system?
Yes, my system is updated every day, but when it stopped working, I do not know :(
Try to download this file in lib folder of xnviewmp
euproko
Post by euproko »
xnview wrote:Try to download this file in lib folder of xnviewmp
I'm happy, this working. Thank you very much! :D
P.S.: The problem is solved. Please close this topic
euproko
Post by euproko »
I have a same problem again, but on a different computer, overwrite the files in lib folder of xnviewmp did not help. Probably because on this computer the system is 64bit (also Arch Linux but 64b and just installed).
