Milestones...
- Moderator & Librarian
Re: Milestones...
We passed the 150'000 forum posts mark! The release of XnView MP v0.99.0 pushed us over the line
Re: Milestones...
More than 500 HQ posts in the past 12 months!
Re: Milestones...
The forum now has a total of 20'000 registered members
Re: Milestones...
According to the administration control panel, this board was started 2 decades ago (12.Oct.2003)
Re: Milestones...
XnTriq wrote: Sun Oct 15, 2023 8:30 am According to the administration control panel, this board was started 2 decades ago (12.Oct.2003)![]()
Re: Milestones...
0.25 centuries
Nview, Nconvert & View2 v2.63
Xnview v1.05b
Copyright (c) 1991-98 Pierre-E Gougelet
All Rights Reserved.
XNVIEW v1.05b (LIBFORMAT v2.63) 20/05/98:
Bug fixes:
- Rewrited XPM functions
- Fixed bug when reading binary Portable bitmap file
- Fixed bug when reading Wavefront Raster Image File
- Fixed bug with 'Logarithmic Lut'
- Fixed bug with De-Interlace (incorrect when choise is 'Odd Fields')
XNVIEW v1.05 (LIBFORMAT v2.62) 1/05/98:
Bug fixes:
- Changed the method of resizing
New features:
- Added 'filter user'
- Added 'fit to image'
XNVIEW v1.04 (LIBFORMAT v2.61) 01/05/98:
Bug fixes:
- Bad number of version in window's title
- When the last window is closed, information not updated (Windows only)
- Best automatic recognize
- X11 bitmap reading caused a crash
- Fixed bug with using DOS filename (8:3) in argument (Windows only)
- Fixed select directory in file selector of MultiConvert (Windows only)
New features:
- File Selector in 'Open Multi' use Explorer Style (Windows only)
- Added support for 15 and 16 bits images
- Added -I option in Nview to display only information
- Added -wmax and -hmax in Nview to specify a maximum width and height
- Added picture's information in File Selector (Windows only)
- Added picture's preview in File Selector (Windows only)
- Added 32/64 and 128 colors converting
- Added tools to manipulate LUT (contrast, brightness, equalize, ...)
- Added filters (Blur, Average, Sharpen, Emboss, ...)
- Added specials filters (Maximum, minimum, ...)
- Added effects (Slice, Swirl, Oil painting, lens, waves, ...)
- Added support of JPEG progressive (jpeg v6.0) for reading
- Added Slide Show
- Added Undo
- 'Window adaptive' keep the ratio of picture
- Added Rotate, Mirror and Negative in Multi/Sequence Convert
- Added Mode in Multi/Sequence Convert
XNVIEW v1.03 (LIBFORMAT v2.60):
Bug fixes:
- Fixed when writing TIFF LZW 32 bits
- Fixed when reading binary GIF, BMP or PCX file (Colormap was inversed)
- Fixed when reading binary RPPM file
- Fixed when writing GIF 2 & 4 bits
- Read 2bits TARGA file is ok
- Softimage with RLE encoding caused a crash
- 'rotate +- 90' flip picture
New features:
- Added Dither in 6x6x6 colors to display in pseudo colors (Motif only)
- French version (Windows only)
- Added 'current' in file selector (Motif only)
- Added X11 pixmap format (read only)
XNVIEW v1.02 (LIBFORMAT v2.59):
New features:
- Added 'Sequence convert' and 'Multi convert'
- UNIX version use the SHARED library of libformat
XNVIEW v1.01 (LIBFORMAT v2.59):
Bug fixes:
- Fixed some bug in the file selector (File extension not changed)
New features:
- XNVIEW now works with Linux and Lesstif
XNVIEW v1.0a (LIBFORMAT v2.59):
o Windows version of Nview/Nconvert
Re: Milestones...
2.5 decades, or 0.0025 millennia...
