GIMP xcf don't display
stockelgurph
Post by stockelgurph »
Hello!
- XnView installed is latest 1.98.5
- default settings don't change anything (renamed whole XnView settings folder in documents and settings)
- OS is Win XP SP3
- GIMP is Windows Version 2.6.11.
XnView does not display any GIMP xcf file.
Either display is completely black, or one of the layers is shown, or one of the layers is shown badly garbled.
Same files stored in another format (from GIMP) show up as should. (eg TIFF JPEG - I think these are without layers.)
I think it has to do with the layering. Or more specific with text layers? Maybe?
If you need a sample (not sure if I'm able to upload anything anywhere), just ANY xcf written with GIMP will do.
E.g. in GIMP "File" "Create" "Logos" "Chrome" (or whatever it is called in other language versions).
Then save as xcf.
That creates three layers, right now XnView is only showing the "Drop Shadow" layer, not the rest of the layers. Or maybe it's an alpha layer, I can't really tell.
Troken
Re: GIMP xcf don't display
Post by Troken »
I have the same problem.
Even with 1.99.6?
Troken
Post by Troken »
xnview wrote:Even with 1.99.6?
It only shows the bottom layer with 1.99.6.
And are able to navigate in the layer with page next?
