[FIXED]RC6: Reenabling columns expands others.
Locked
marsh
Post by marsh »
Disabling and reenabling file size column expands all of the columns to the right, except date. Previous column widths are not remembered.
There is an issue…
:) Hello !
- I checked this here. Although I don't get the same exactly (?), I confirm that there is an issue :
- I disabled the file-size, then -like you say- the other columns didn't keep their previous widths; i.e. : the “Properties” column has been reduced and its caption truncated with "".
- Enabling the file-size again restores all alright…
- I use the layout #4 (from up to down in the menu) always, but I don't think it does matter…
:mrgreen: Kind regards,
marsh
Post by marsh »
I'm using Layout #3 with no folder tree.
Well---
• Well, so we can say that the layout doesn't matter ;)
:mrgreen: KR
Re: RC6: Reenabling columns expands others.
marsh wrote:Disabling and reenabling file size column expands all of the columns to the right, except date. Previous column widths are not remembered.
I've just tried to reproduce this problem and found the following behaviour:
Whenever disabling or enabling (showing or hiding) a column using "View > Columns", XnView resizes all other column to some value (possibly an internal value). And it doesn't matter which column you show/hide.
(Windows XP SP2)
right i fix it
Locked
