its possible to support WebM-Writing
i think it should be possible to produce WebP-Images
an combine it in a WebM-Container (every image is B-Image)
with a possible to use this container as Multi-Image-Format (similar GIF/MJPEG)
if this is possible it would be nice to have a good alternative to CBR/CBZ-Comic-Reader-Format
tnx
Add WebM-Support
Re: Add WebM-Support
WebP is supported, i'll check for WebM-oX- wrote:its possible to support WebM-Writing
Seem to be not implemented - right?
Peter
Peter
Pump up - some news since Dec. 2011?xnview wrote:WebP is supported, i'll check for WebM-oX- wrote:its possible to support WebM-Writing
Peter
