can't set file associations
Mr Zombie
Post by Mr Zombie »
Hi!
Setting the file associations under options doesn't work. The files won't be opened with XnView when I double click them.
I am using Win7 64bit. Running XnView as admin didn't help.
Re: can't set file associations
Do you running XnView with context menu "Execute as admin"??
Mr Zombie
Post by Mr Zombie »
to be precise: I run it with context menu "Run as administrator"
Mr Zombie wrote:to be precise: I run it with context menu "Run as administrator"
Which association do you try to set?
Mr Zombie
Post by Mr Zombie »
I've tried jpg and png. Neither of them work. But XnView seems to remember which file types I have checkt after a restart.
I use ini file by the way.
Mr Zombie wrote:But XnView seems to remember which file types I have checkt after a restart.
If you go in XnView, pnb&jpg are checked?
Mr Zombie
Post by Mr Zombie »
yes, they are checked in xnview. But they won't be opended with xnview when i double click them in windows explorer
Mr Zombie wrote:yes, they are checked in xnview. But they won't be opended with xnview when i double click them in windows explorer
Which software is opened?
Mr Zombie
Post by Mr Zombie »
IrfanView.
Ok, right, if an application create a 'UserChoice' key, XnView can't override it... I'll fix
Mr Zombie
Post by Mr Zombie »
thank you, looking forward to it.
Elendil0
Post by Elendil0 »
Hi, I've same association problem :
xnview doesn't open anymore when I lauch a .jpg file for sample.
When I go to Options Associations, "jpg" is already checked ; I uncheck then check again => it generates an error window "ERR5, msg1, OK".
But nothing changes.
I'm under Win 7 64bit, with a 6 months old version of xnview that I updated for the occasion (1.98.8_ )
Is it the same issue that you've plan to fix?
Elendil0 wrote:Hi, I've same association problem :
You have the 1.98.8 and option/associations doesn't work???
bar_foo
Post by bar_foo »
I'm having exactly the same problem, also in Win7 64 bit. I've tried running as admin and it doesn't help. XnView is also not an option in the Open With menu for image files.
bar_foo wrote:I'm having exactly the same problem, also in Win7 64 bit. I've tried running as admin and it doesn't help. XnView is also not an option in the Open With menu for image files.
do you have installed from the zip or setup?
