Keep Print Size on Batch Processing>Resize
Squashed
Post by Squashed »
Hi Pierre,
Could you please add a checkbox for Keep Print Size on the Batch Processing>Resize Parameters? I want to change the image height in pixels and have the dpi calculated automatically. Currently, if I change the image height, the dpi remains the same and the print size alters. Thank you.
Re: Keep Print Size on Batch Processing>Resize
ok, i'll add it
