Unknown format
Guido
Unknown format
Post by Guido »
I'm using GflAx.dll to convert pdf-documents to png. On 32bit Windows this is no problem but on Windows 7 64 bit I'm receiving the error "GflAx error: unknown format". The error is given while executing gflAx.LoadBitmap(selectedFilePath). Ghostscript 64 bit is installed and GflAx.dll is registered. I know for sure that the variable selectedFilePath has a valid path assigned.
My code is:
try
    GflAx.GflAx gflAx = new GflAx.GflAx();
    gflAx.EpsDpi = 100;
    gflAx.SavePNGCompression = 7;
    gflAx.Page = 1;
    gflAx.LoadBitmap(selectedFilePath);
    gflAx.SaveFormat = GflAx.AX_SaveFormats.AX_PNG;
    gflAx.SaveBitmap(image);
    pictureBox.Left = 0;
    pictureBox.Top = 0;
    pictureBox.ImageLocation = Path.GetFullPath(image);
catch (Exception ex)
    MessageBox.Show("GflAx error: " + ex.Message);
What am I doing wrong?
Thanks,
Guido
Re: Unknown format
It's a known issue of GFLAx
vivek.kumar
Re: Unknown format
Post by vivek.kumar »
Hi, anyone has got the solution of this problem. I have wasted 3 days and not able to find the solution or work around for this.
Thanks in advance for your help.
Regards,
Vivek
Re: Unknown format
Do you have last GFLax?
