RC6: Tips. Next tip button don't work
Locked
ckv
Post by ckv »
Subject says it all.
Edit:
helmut wrote:Pierre has changed the language code in the tip.ini from [uk] to [gb], but RC6 doesn't support the language code [gb], yet. So only the internal tip is shown. Changing the language code to [uk] in 'tip.ini' will show the other tips. (Temporary Workaround)
So there are actually two issues:
a - Support of language code [gb]
b - When only one tip is available, the Next button should be greyed out.
Re: RC6: Tips. Next tip button don't work
ckv wrote:Subject says it all.
ckv
Post by ckv »
Oh! OK. Thanks helmut.
helmut wrote:So there are actually two issues:
And one thing more. When 'Do not show tips...' is selected and you click 'info/Tip of the day...' the 'Do not show tips...' checkbox is uncheked.
ckv wrote:And one thing more. When 'Do not show tips...' is selected and you click 'info/Tip of the day...' the 'Do not show tips...' checkbox is uncheked.
I think that is correct. When chossing the menu item 'Tips of the day...'. you see the dialog. Then you decide whether you just want to read and close it. And if you want to display it always at startup, you uncheck the 'Do not show at startup'.
ckv
Post by ckv »
But it don't work in that way. I mean there are no way to get tips on startup back after you have disabled them.
Edit:
When you have tips allready disabled then it should be checked when you go to tips in 'info/Tip of the day...' and if tips are on it should be uncheked, but now it always uncheked. That's the problem.
ckv wrote:But it don't work in that way. I mean there are no way to get tips on startup back after you have disabled them.
You're right. That's a bug.
ckv wrote:Edit:
Yes. When opening the tip dialog using the menu, the checkbox 'Don't show tips at startup' should be check or unchecked, depending on the setting that is active at the moment. Then, the user can change the setting and this has to become the new setting, then.
ckit
Post by ckit »
This has been fixed in RC7.
Dreamer
Post by Dreamer »
Confirmed.
Locked
