cmd_WebPage for plugin-supported formats
Moderator & Librarian
When I try to create a Web album of DWG files in XnView v1.80 or v1.82, I'm presented with the following error message:
Format of the file <X:\TEST.DWG> could not be determined
For display of less common format, the following option is available:
  • Options>General>[x]Display all image file types
Would you like to continue?
[ OK ] [ Cancel ]
This setting is enabled, and CADImage.dll is installed properly.
I know for a fact that I was able to generate an HTML gallery for files of this format about three years ago with older versions of XnView and the CADSoftTools plug-in.
Re: cmd_WebPage for plugin-supported formats
Strange i've tested, and no problem...
Solved!
I had to install %ProgramFiles%\XnView\Plugins\CS_Manager.exe.
  • Image
  • Image
The settings are saved in the registry: HKEY_CURRENT_USER\Software\SoftGold\
Soft Gold ([url=http://www.cadsofttools.com/en/products/plugins_for_3d-party_programs.html]Plugins for 3d-party programs[/url] » CS_Manager) wrote:
Small free application allows to:
  • Input registration data
  • Change size of CAD image (DIB)
  • Change between color and black-white mode
