Problem with Pentax RAW (PEF)
Discussions on XnView for PocketPC
badworm
Post by badworm »
I'm using XnView Pocket 1.40 at HTC Universal (also known as SPV M5000, XDA EXEC, MDa Pro, Qtek 9000 and some other names) with Intel PXA270 processor and Windows Mobile 5.0. Everything is working good but I can't open RAW files (PEF extension) from Pentax K10D digital camera. When I try to open such type of file, I get an error message: "Problem to load (path and filename)". Where is the problem? Does this version of XnView Pocket not support files from K10D - only from older Pentax digital cameras? Here I placed a sample RAW file from Pentax K10D camera: http://badworm.enetia.pl/foto/2055.PEF
Re: Problem with Pentax RAW (PEF)
You use XnView Pocket to view your RAW files?? not slow?
badworm
Post by badworm »
I would like to use XnView Pocket to view RAW files from Pentax K10D DSLR. If I can do this, then I will be very happy - I will have one program at PPC for viewing and simple edition for JPG and PEF files :)
I'll try to build a new version
