MP 0.39: Export does not export edit image
Not sure whether this has been reported before:
When cropping an image and then exporting it, XnView MP will export the original image, not the cropped image.
1. Start XnView MP 0.39
2. Open an image
3. Crop the image
4. Export the image.
--> When opening the exported image, you will see the non-cropped image, which is wrong. :bug:
budz45
Re: MP 0.39: Export does not export edit image
Post by budz45 »
That's because the image has not been saved first before cropping..... So the "Export" function needs to be fixed/feature added to be able to even preview unsaved cropped images. Seems quite simple.
Zverik
Post by Zverik »
I confirm this. Since 90% of my editing in xnview consists of cropping/rotating and exporting, this bug is very disappointing.
Zverik
Post by Zverik »
Another result of this bug I've found two days ago: if you import clipboard into xnview, Export dialog just does not open. I had to save and then reopen the image.
Please check XnViewMP 0.48
